Switching on& Off LineWeights
Is it possible to swhitch On & Off the lineweights on the model and paper space?
Like conventional CAD softawares do.
Hi MNT- use the PrintDisplay command for this.
Pascal
Thank you for the reply.
what does the thickness relate to? is it the actual width specified in the layers, multiplied by the scale factor?
thank you
Hi MNT- yeah, in model space the number in PrintDisplay is multiplied by the object’s Print Width, divided by 10… then the resulting number is the displayed width in pixels. So, a print width of 1 and a PrintDisplay Thickness of 40 (default) should draw as 4 pixels wide.
@margaret, I don’t know if this info should be in Help maybe?
