Sweeping 2 lists of curves - why doesn't this work?
contour along curve.gh (12.4 KB)
bench.3dm (1.1 MB)
grasshopper file and 3dm attached
Thanks!
It fails because the curve ends / seams are not in the right place
are you sure? when I do the sweep command manually in rhino with baked elements it works.
contour along curve.gh (13.4 KB)
Increasing the number of perp frames is problematic. I have not found out yet why.
What’s the goal of your definition? There may be a better aproach.
something like this
the script you posted almost works, will work with this. thanks!
Next problem is your text panel with the 1.5708 input which should be replaced with a pi/2
good tip. will use that in the future. still some missing ribs.
One problem I see is the curve in the cyan group (below) is centered in the sweep geometry in top view, which can cause PFrame section curves to overlap. It works better to have the curve generating the PFrames to be at the smallest “center” of the sweep shape so section curves based on planes radiate out without overlapping.
contour along curve_2022Jan20a.gh (29.8 KB)
There are other problems even at low number of perp frames.
Sweep2 works fine…
contour along curve.gh (16.5 KB)
wow this looks great. thank you for taking the time to do this. I really appreciate it. enjoy your evening!
