Sweep2 with chained sweep shapes?
Hello.
I use history to create surfaces so I can adjust their shape later.
I often need to split a curve to create surface (see green surface), which breaks history.
As a work around I create a copy of the curve I need to split and work with it instead, this is ok until I need to adjust that curve later, that creates non water-tight edge with adjacent surface (red), so then I have to delete original non-split curve and surface that was created with it, create copy of the curve that is split, join it and recreate red surface with it. This is absolutely pain the ass process.
What would be my best option in this case, like a sweep2 that would allow chained sweep shapes?
Thank you.
P.S.
I wonder what was the reason not allowing chained shapes to begin with?
Can you post a file with the curves? i’ll take a look at history-friendly options.
Sure.
Sweep2_chained_shapes.3dm (261.6 KB)
I just realized I mixed up the terminology here, it’s the chained shapes I wanted be able to select…I corrected original post
