Yeah, I guess ideally in this case you’d want that edge normal to the target surface, and so on, correct?
He posted above:
No, that’s why I tried your cage edit script.
To respect the normals, _FlowAlongSrf is the tool of choice.
Also this is more fiddling, I have to build a good target first - not necessary with ProjectObjects.
Even with _FlowAlongSrf, the result is not as wanted.
Perhaps it’s good enough, I have to re-ask the customer.
As the initial issue was bad surfaces from _Sweep1, I tag the thread as solved now.
