Hi to all,
I need a “ring” from a periodi curve (rail) and a closed curve.
I’ve create a periodic curve (interpolate) from given points, but the sweep1 rail doesn’t work. I don’t undersatand why…
sweep1rail.gh (10.6 KB)
Hi to all,
Hi Lago Filippo
You can create it useing seam component.
Please found this atteched file.
thanks,
Thank Reo,
it works now.
So the problem is the perfect starting point position…
Thank Dowazura,
it works too, but i hoped something… simplier
What does it mean to be simpler?
Less elements to use
