Sweep rectangular beams along a curved surface
I am having difficulty sweeping a rectangular shape along vertical and horizontal curves made from a curved surface. I divided my surface into multiple planes specified by a specific spacing and tried to use those curves as the rails to my sweep. They all should share the same rectangle base shape.
If anyone has a more efficient way to create this in grasshopper, any tips are welcomed!
Thanks
LD test_iternalised data.gh (534.2 KB)
You flattened your data tree in Orient Direction - so then you were asking Gh to sweep 552 curves (and some nulls) along 23 rails
You could try something like this instead
don’t flatten
LD test_iternalised data_tree.gh (532.9 KB)
3rd
  • cull nulls.
Thank you for all the helpful tips. I tried this in the other direction and received the same error. The error message reads that the parameters are out of bounds. How shall I go about this?
Also is there a way to do this sweep with existing curves in rhino rather than curves made from grasshopper?
Thanks in advance!
LD test_iternalised data_update.gh (591.2 KB)
Just Graft the curves at the start - that way Grasshopper can tell which Sections and Rails are related
