Hi, I am running on V5 and it happened that the Sweep1 command does not work properly as it does not build edges. It was working fine previously. I have checked it in V6 and that wokrs just fine. Is there any settings that controls the Sweep1?
i do not have a running V5 rhino but i think:
check _creaseSplitting command / option:
http://docs.mcneel.com/rhino/5/help/en-us/index.htm#commands/creasesplitting.htm
if you want to modify already created surfaces:
_split isocurve = yes, split = yes, snap to Knot
kind regards
Sweep1 is working correctly. As @Tom_P suggested the different results are probably the result of different CreaseSplitting settings.
Thanks the CreaseSplitting solved this.
