How do I adjust the curve of the sweep to achieve a more rounded edge? Its assuming the angle of the curve between the two cross section curves perhaps based on the base curve but I’d like to change it. Is there a better way or what am i not doing?
Post a .3dm file with the geometry. You can drag the file to the where you type your post, or use the vertical arrow in the bar above where you type your post.
Which command did you use - Sweep1. Sweep2, ???
Hello - in this case it probably is simplest to loft the four curves with a ‘Straight sections’ style loft.
Does that get what you need?
Thank you so much! That was very helpful : )
