Hello comunity i have a problem trying to make a surface with a complex surface it has curves in more than one axis and this is the problem i am uploading the file and the photo of the real product, any hints or help will be much appreciated.
David
Drawing3b.dwg (50.1 KB)
Hi David - are you looking to fill in the missing bits? I would do something like the attached file-
ExtractSrf, then ExtendSrf the white surface. The Cyan surface is a new extrusion from the line in the file.
Green srfs are FilletSrf at 11 and red are FilletSrf at 1, then some trimming to clean up. Drawing3b_PG.3dm (365.5 KB)
Thank you so much! it is exactly what i was looking for!
