When I work with a single curve, I can get the surface I want without any problems. However, when I work with multiple curves, the Sweep 2 operation does not work.
sweep 2 problem.gh (21.4 KB)
It works—to keep your current system: Weave instead of Entwine will help here.
sweep 2 problem.gh (28.7 KB)
Hi Deneme,
You only need one section curve per sweep unless you want to segment the sweep in a particular way. Let me know if this works.
Sweep 2 Problem - DM.gh (22.5 KB)
Why don’t you extrude and fillet?
Not answering for @deneme but while entertaining a related thought I realized the sweep sections aren’t arcs nor interpolated curves so fillet will produce a different result/object? I didn’t check, perhaps this is irrelevant in this case anyway.
Thank you very much for your kind attention and help. Thanks to you, I got rid of a big problem
