Sweep 1 troubles
What goes on with sweep 1? I try to use it for applying mouldings around kitchen door panels. Sometimes works sometimes doesn’t. Sometime works on one plane but not in another. Please help me gain control of my sweeps.
Sounds like you are very frustrated. But without more specific information no one will be able to help you. Upload a .3dm file with an example of input curves which result in Sweep1 not working as you expect. Also run the Rhino command SystemInfo and post the results.
