I am new to Rhino3d and came from SketchUp. I am redoing some of the objects and one action I can’t seem to get right. Here it is: when I sweep 1 Rails, the end results has sections what are squared. I would have expected a rounded object. Here a rectangle around a circle. Once exported the result clearly is segmented and non-round.
A finer mesh - that certainly solves a part of it. On the screen I can see the more fine grained details, but when exporting (to step file for instance) it retains the coarse mesh …?
I must belief Willem Derks is here on the right track: the viewers may the culprit. Using FreeCad and CadExchange, those tools retain the coarse segments. Reimporting a step file back in Rhino3d does show a smooth circle.
It may be the cad programs do apply a similar thing as Rhino with mesh properties, but in Rhino3d you can modify this and in the viewers you cannot.
I will try a revolve too, just to see if that makes any difference.
In the end I learned that the mesh settings are the problem, and mesh settings are client settings. Even in the “simple” CadExchange, I found the option to increase the mesh properties to a more fine level, solving my problem as it was never there. Indeed it wasn’t a problem, the drawings are precise. It is the rendering/representation of it that can deviate for performance reasons.
