Sweep 1 of more than a section
Hi everyone!
I have done the script to oriented and sweep the section of my slab along the rails i have previously selected and it works.
At this point i want to do the same with the section of the veils, they are two aside the slab, so I choose “select multi geometry” in Orient but then the sweep button became red and i don’t know where is the error.
Here a screen to clarify how is my section. Basically i want it along the rail that i have created, i can’t draw it with just a polyline bc this element will change a lot in the netx days and i’m using grasshopper to avoid to re draw everything everyday
So, at this point, i have tried to do the sweep of just the two veils but instead of do it along the rail it does the sweep perpendicular to it!
If i just put a single vail it works as i want but i would like to avoid a script for each veil bc i have already a lot of other scripts and they basically would do the same thing!
Here is my file
Sweep Problems.gh (15.1 KB)
Sweep.3dm (33.7 KB)
I hope someone will be able to help me bc i’m pretty desperate!!
Marianna
Here are two ways of doing it.
Sweep Problems_re.gh (22.8 KB)
Thank you so much Kim!
I’m going to try it immediatly
