Challenge:
There is a grasshopper model, containing multiple ‘surface’ containers.
I would like to use this for another grasshopper model.
Unfortunately, the other model does not contain surfaces, but points… ( the rest is the same)
Because there are points inserted into the surface command, it does not work.
Question I would like to ‘swap’ a surface command, with an ‘data’ command and keeping als the attached relations.
(Because now I have to manually to delete the surface commands, insert the data command + adding again all the relationships…And I have a lot of them…)
Any suggestions?
Thanks
2020-04-28 Swap Surface and data command.gh (5.3 KB)
