SVG Import Invisible in Beta 9
BETA (9.0.26202.12303, 2026-07-21)
Importing a SVG (PCB pads and edge cuts) the edge-cut rectangle is there but invisible in the BETA.
Import the same file in Rhino 8, you get a visible rectangle for the board outline.
(SM_PowerDwn2.svg is just the board outline, without pads)
AutoPowerDown.zip (7.2 KB)
The Linetype of the rectangle lines comes in strange.
stroke-width:0.0019685
I think that is not friendly interpreted, the linetype width in Rhino is 0.00.
If you need a workaround:
I loaded the SVG in Affinity and exported a new SVG.
Thanks Charles, I also found I could us a BoundingBox to get the rectangle, but for now just went back to Rhino 8. My main reason for posting was to alert McNeel devs to the regression.
I thought so.
Hopefully they read it.
