I am trying to export curves/lines from Rhino 6 to SVG format.
No matter what settings i use, I always get an empty 1KB svg file.
I can see the lines I want to export in the export preview window, but when I do the export itself, nothing is exported. I open these 1KB files in Illustrator or Affinity Designer, both show nothing.
Am I missing something?
Update:
I did some more digging and found out that if I copy the exact same curves to a new Rhino6 document and export from there it works…Anyone knows what bug this is?
Some additional details might be helpful to the developers:
What is the pedigree of the original file which produced the empty export? Created in the same Rhino 6 instance from which you tried to export? Created and saved from an earlier version of Rhino 6 then opened in the version that exported nothing? Imported from Rhino 5 or a different CAD program? If so what format was used?
When you copy the curves to a new document do you do this via a second instance of Rhino open at the same time as the source instance? Drag and drop?
You could also use my exporter to SVG but it works just in Rhino 5 and it will add a second exporter in rhino 6 menu. And no luck it is exactly the same wording !
The original geometry is created in Rhino 6 with Grasshopper.
I made a Make2D from the geometry and tried exporting it from there, the same rhino file.
No Rhino 5 was used here.
I then opened a second instance of Rhino 6 along and just copy/pasted the Make2D curves into the second instance and just used the Export command.
@Lauent, Thank you for the suggestion. I will give it a go.
