Hello!
Anyone has any idea why this box morph command doesn’t work correctly. I cant find where is the problem with the volume of my reference bounding box.
Phase_B_26_3.gh (647.1 KB)
Thanks in advance
Hello!
Thanks in advance
You are awsome!!
But… You need to look at why ‘Union Box’ is necessary here at all, when ‘Geo’ appears to be a single surface? The reason is that ‘Geo’ is a list of three surfaces, two of which are tiny fragments that should be ignored. The third one (the one you want to use) is a actually a brep, not a surface.
Thank you, Joseph!
So in case, I would use a ‘brep’ instead of ‘geo’ in this specific case it wouldn’t be necessary to check union box?
PS . I am really impressed with this forum and you guys. I am happy to be here!
‘Union Box’ is used when you want a box to enclose all items in a list/branch. If there is only one item in the list, it isn’t necessary. The problem isn’t the box, it’s that all three pieces will get morphed, including the two stray fragment surfaces.
