Surfacing aircraft nose from ordinates
I’m trying to surface an aircraft nose from tables of ordinates from the mfg. If I trace all the sections with interpcurves and loft everything up to the windshield I get a surface with a zillion verts which I can’t really edit. The curves are rather lumpy and don’t lend themselves to lower order nurbs.I watched the series from thirtysixverts which opened my eyes to the idea of simpler curves making the surfaces easier to edit but he didn’t specifically address drawing from ordinates. For some reason even a 7th deg nurbs curve would not accurately reproduce the sections except at the very front where it was almost circular. The top corner has an abrupt curvature that the nurbs can’t reproduce.
If I draw through all the points to define sections using interpcrv I get this. If I try to do surface from network curves it fails. I can loft but I get a million verts. If I use network curves and use just a few sections it works but I still get so many verts that I can’t really sculpt it and the chances of it being able to match an adjacent surface is probably zero. One can see that it is a lumpy strange surface and the software struggles to define the surface at the bottom corner of the windscreen probably because it lacks data. The control points show a corner there forward of the windscreen that is not on the airplane.
Can any of you suggest the best strategy to loft this? Small patches? Top and bottom quadrants and then patch in the bit in front of the windshield? The rest of the airplane is quite simple but this nose has me stumped. Or any suggestions on other videos where this has been addressed?
That’s very much like a “bullet train” cab/front end. Without a photo of the foam mock-up, clay model, or real thing, it’s hard to suggest how to go about the tricky windshield area. The point cloud lacks detail in the difficult places. In general, I’d develop a patch layout and then use NURBS surface modelling principles. Maybe what I futzed below gets you started, so you have something you can look at in 3D while working out the windshield area. You’ll likely need some overbuilding/trimming in that area.
If you are a professional stalker like me you will find gems here and there on this forum
I found @JimCarruthers website a while back it has an aircraft modelling tutorial, it’s ancient from the year 1769 but it looks like a good one for aircraft that will give you the idea how to approach aircraft modelling
Lots of more gold if you dig deep enough.
here is the actual aircraft. It’s a bit lumpy but now that I look at the photo it isn’t terrible. It has a huge bulge just above the air scoop which complicates things.
The bulging region you can add by insertion once you have the large primary surfaces down. A photo from higher up would be very useful to understand the tricky area and work out a patch layout for that one.
What is the origin of the ordinates?
Aircraft manufacturer engineering (not promotional) drawing?
High accuracy scan of an actual aircraft?
Scan of questionable accuracy of an actual aircraft?
Scan of a model?
From a third party drawing?
the ordinates are from the mfg master lines document which dates probably from the late 50s so back in the days of wooden splines and pencils and mylar. This is their official definition of the outer mold lines of the airplane.
So two things would be
1)It doesn’t matter where those numbers came from they’re not accurate enough to get a nice fair surface by trying to force a surface through them, nor are they the actual coordinates you would want to feed into any surfacing algorithm. They’re just something you can check against.
2)“Making a bunch of sections and lofting” is not how you make…anything with NURBS. That should probably be done with separate surfaces for the top, bottom, and side, that all converge at the tip of the nose. And at least another one for the cockpit. Just to say very vague things in a few seconds…
My first attempt would be to ignore the windows/canopy area for starters as it is complicating the problem. It can be trimmed out of a fair body and modelled separately. In real life, this looks like how it would’ve been manufactured, which helps with your reverse engineering problem.
Concentrate on the fair body first. Build a simple surface model, blended onto a profile on centreline. Then use PointDeviation to fair it to the points within tolerance. The tolerances may even be on the manufacturers drawings.
Then model the windows/canopy and blend into the body.
For the purposes of making a 3d printed model and later an RC model I can just use the ordinates as a guide. if it deviates 3 or 4% it doesn’t really matter. So if sections and lofting is not the way (which I have proven) what is?
@Lagom has given you a pretty good starting point for laying out some surfaces. @NickB has suggested how you can tweak those surfaces into some tolerance of your point cloud. I’ll add the advice to seek out - if you haven’t already - the ThirtySixVerts channel on YouTube and learn how to surface from a master. It’s a standard recommendation for every Rhino user.
Regards
Jeremy
Perhaps the numbers are accurate, and the original aircraft as designed and built over sixty years ago does not meet current expectations of “fairness”.
I mean it’s probably not “fair” at all, but moreover the numbers you need to feed into a surface-creation algorithm need basically infinite accuracy.
I suspect given the type of airplane they laid out all the stuff they had to stick into the nose and then wrapped a random shape around it. It was a low speed aircraft so the aerodynamics weren’t critical. that company was used to building bush planes so it was definitely a low tech approach.
I certainly did go through his series. That’s when I found out that everything I was doing was wrong!
Start with a rough and simple surface then manually control point edit it to tolerance.
This is the way.
Maybe also the NURBS surface modelling principles with respect to Rhino usage could be useful, and the Autodesk Alias theory links at the end that also the videos @jeremy5 mentioned refer to. Then start by establishing a suitable patch layout as I suggested above. Without a patch layout concept, you can get lost in endless noodling.
I usually go by a Curve Network / Patch layout.
For reverse-engineering an old airplane, another, quicker route would probably be to use NURBS for the wings and tail surfaces, and SubD for the fuselage. Then convert the SubD fuselage to NURBS before slicing it up for further detailing. That way, the general shape of the fuselage is inherently G2.
Here is a test I did some years ago, reverse-engineering an Aerovan using this process.
Mock-ups before CAD:
I’m starting to get it. It’s a very lumpy surface but I’m starting to figure out the tools.
