I was trying to illustrate a problem I was having where green would not join red on a tangent. As I was trying to simplify the problem for posting here I ran into another problem: Red and Green would not joint at all.
Here’s a little discovery. I had thought that I had copied the tolerance from the source file to the destination file. Instead, it was the default 0.001 rather than the 1/128.
If the tolerance is 1/128, creating the surface using the curves in the file creates the funny extension on the curved edge.
If the tolerance is 0.001, the surface looks fine and joins.
