Surfaces and polysurfaces not showing up in arctic
I had a similar problem before and solved it by changing the material but this doesn’t seem to work for these ones is this just a property of artic not showing the differences in the colour of glass?
artic shows everything as the same material by default.
if you need multi materials in artic, use SetObjectDisplayMode
and change those objects to rendered, with a material of your choice.
