I’m having some problems. First, the split is not cutting the surface. Then I can’t make the attractor points connect with the surface created to change the hezagon grid. It should look like the following image
Rhino failed to convert .JPEG to .GH
Upload code.
I don’t know if I understood what you meant
If you want help upload your grasshopper file.
AGORA SIM.3dm (93.0 KB)
AGORA SIM.gh (20.7 KB)
I changed some things, but when I try to generate the patch on the hezagonal mesh it generates it outside the limits of the initial surface
I haven’t looked at your code but patch and mesh sound like you have gone off track. Stay with surface and avoid Patch
I managed to solve it including the explode command
