Surface UV not updating when using Box Edit
I discovered the other day that when using box edit to change the size of a surface it does not update the UV values.
In the attached example, there are two surfaces side by side of the same height and width. But when evaluating the UV coordinates, one says:
Geometry:
Valid surface.
surface.
Plane Surface
“U”: (0.0000000 <= U <= 60.0000000)
“V”: (0.0000000 <= V <= 156.0000000)
And the other says:
Geometry:
Valid surface.
surface.
NURBS Surface"U": degree =1 CV count = 2 (0.0000000 <= U <= 48.0000000)
“V”: degree =1 CV count = 2 (0.0000000 <= V <= 120.0000000)
They both have an equal area of 9360 square inches.
The only difference between the surfaces is that the one that has a max U of 48 and a max V of 120 was stretched using box edit.
Is this normal behavior or is this an error? Using box edit to change the height or width of a surface is pretty handy so it seems that it should be updating the UV coordinates?
I tried using the Rebuild command to see if that would do anything and that didn’t help.
Any help is greatly appreciated.
Surfaces.3dm (68.7 KB)
Hi @Tom_Peterson1,
This is expected. BoxEdit, like Scale, transforms the surface’s control points but leaves its parameterization alone, so the U/V domain doesn’t change. Rebuild also keeps the existing domain.
If you want the domain to match the surface’s size, run Reparameterize and choose Auto. That sets the domain to roughly match the edge lengths. You can also type in the U and V ranges yourself.
– Dale
That’s what I needed to know. Thanks Dale!
