Surface Treatment component
Is it possible to manipulate Surface Treatment properties like pattern type and tile width etc… with Tekla Live link component?
surface_treatment.gh (16.4 KB)
Hi Aleksander,
Those attributes are UDAs, curiously. If you inquire the object you’ll find the names to use.
And you can then set them as UDAs:
Cheers,
-b
Hi @sebastian.lindholm,
I tried using UDAs, but I couldn’t effect any changes in attributes. Your hint proved invaluable! I realized I was inputting attributes values as integers. These parameters only accept real numbers, hence ‘TILE_W 220’ doesn’t work, whereas ‘TILE_W 220.0’ does.
Thank you :slight_smile:
