I am seeing an odd thing when converting a simple planar surface with a transparency applied into a block - the resulting block is more opaque than the surface was before it was “blockified”. Below is an image showing the result - note the change in color of the original surface with 50% transparency when it is made into a block using the Block command. As a comparison, hatches do not seem to be affected in the same way.
Is there an explanation for this?
SrfHatchBlockTransparency.3dm (2.0 MB)
