Surface thickness is 0 yes?
does a surface have no thickness unless it is extruded?
this may be a cam question, but i have two mating parts that are made of three surfaces that make a pocket and receiver that should fit into the pocket. i made the pocket first, then just rotated it 180 degrees to make the surface i could cut for the part that is supposed to fit into it. the parts don’t fit well at all and i have checked cutter diameter and comp settings in rhinocam and do not see an error.
i’m asking here as there doesn’t appear to be a good community for rhinocam. i ran the same surface in my old mastercam and got slightly different but similar results.
if need be i can upload a file, i’ll just have to make it smaller as it includes lots more details that are unrelated.
here’s the file. pocket is on the left, right end is open. when i cut the red surface on the right the flat on the top of the part is wider than the flat in the pocket, like i had cut it with a smaller tool than programmed for.
trap mate.3dm (163.0 KB)
these two parts are identical in Rhino… the error is happening somewhere else further down the line… i’m not sure where and i don’t use any of the additional softwares you’ve mentioned.
i don’t think it will change anything in CAM but the individual surfaces making up each part would generally be Joined together as a polysurface
edit-- but to answer the thread topic title…
yes, surface thickness is 0.
thanks, i suspected so. have not run into this before with nested parts.
any other rhinocam users here?
