Surface Texture Drafting Symbol
Where can I find the Surface Texture (Roughness) symbol?
Those to whom I’ve submitted Request For Quote are wanting that annotated.
Thanks
Hi David -
There are no such symbols in Rhino. You will have to draw that manually.
Hi Wim -
Thanks
~ David
Hi David,
Just draw it once and save it. Then you can insert it anytime you need it in the future.
Just to add to this…
David tagged the post with “rhino5” so I didn’t mention this initially, but, in Rhino 7, you can create an “attributed block” so that you can input the roughness value per instance if that is something that varies between locations/parts.
