Surface split
GH ERR.gh (53.3 KB)
hello everyone, attached is a grasshopper file i am try to do a launchbox surface split for further pattern texture…but as seen it doesnt completely split the surface. need help if there are other ways to do this
graft this:
hi, thank you…but i tried this now and i still get the same result, could you assist with this gh file so i can check properly how you did it?
If you cann’t get the result as inno showed, maybe you can have a look at this, it worked for me.
this worked…thank you, can i send a message, i just started learning algorithmic modelling,i need some guidance and i could learn from your expertise.
