I just noticed that these handy little continuity tags appear now when surface points are switched on. I was initially excited that these might be a way to control the continuity, but they appear to behave as a continuity lock, so don’t necessarily indicate the state of the actual geometric continuity.
Here, the small surface has been created G2 continuous with the 2 long surfaces.
Here, the surface is clearly not G2, but the tag still says G2
I understand that this is a lock to avoid knocking out the relevant rows of cvs, but it’s also a bit misleading as it could still indicate to a user that the edge is G2. Will this be made clear with some sort of UI update?
Thanks!
