The attached surface has 2 points in 1 corner. This has generated issues that are problematic for getting to water tight and symmetry in the final model. all efforts to reduce 2 down to 1 points in that area fail. I need to clean this up so that the model can be EDM into existence.
The fix was pretty easy. When I zoomed in the two control points I figured out that they were apart from each other. Then I simply moved the lower one to the other one using point snap. Now there is a single control point at that particular area.
This is a Rhino 5 file, because I had no idea which Rhino you use. For some reason that model saved into a 13 MB file when I used “Clear analysis meshes” and “Export selected”. Then I opened it again, created a simple box, then selected your surface and used “Match object properties”. That removed its original material and object colour. Repeating “Export selected” resulted into a 223 kb file: BadRamp fixed.3dm (223.1 KB)
That worked… I tried exactly that previously, but I must have
used the wrong point in the move. When I zoom in that closely, the display shows nothing that indicates what the larger image is. Easy to choose the wrong point. >SetPoint< is good in this scenario but we just need to choose the right solution.
