I have this converted t spline object that I need to connect to.
I want to use surface network, but the t spline object converted into two pieces, so I can 't connect to it, it selects two edge curves. I’ve tried merging but no luck, duplicating the edge and join to one curve works but then I miss the continuity. What would be the right approach here?
The two surfaces are trimmed surfaces so MergeSrf will not work directly.
ShrinkTrimmedSrf the two surfaces to eliminate the trimmed areas. .
MergeSrf the two shrunk surfaces into a single surface.
You can see there are no curves in the top view of your original model, you were using the edge of the surface which was split but the other end of the shape was using a closed curve:
ExtractIsoCurve on the two faces of the split collar at the bottom of the shape and copy all the edges of the split collar. Join all the curves and then run the _NetworkSrf command to make it into one flowing surface.
