Surface is not merging
i use Boolean union, join & merge all coplanar faces
srf not merge.3dm (112.2 KB)
What are you hoping to “merge” there? You’ve managed to create wonky non-manifold geometry that of course screws up all sorts of operations. If you Join up just the surfaces I think you want to merge, that works.
srf not merge.3dm (108.0 KB)
can u send me a video
Yeah that’s “illegal” geometry. You’ve got closed solids with extra surfaces hanging off of them, that’s “non-manifold.” The issue here is how that was allowed to Join up at all.
If I select just these surfaces and Join them and run MergeAllCoplanarFaces, they merge fine.
:joy:
i Don’t want that 4-line
did u merge ?
Yes I merged them, those are the edges of the other objects behind that are still there and exactly on that same plane, so they will of course be visible.
When modeling with NURBS (and actually this goes for meshes as well, but meshes are more forgiving) you need to make sure that your edges line up.
If you want to join two surfaces, they need to share edges. If there are more than two edges, if one has an edge and the other doesn’t or if they share only a single point (eg. two cubes sharing a single point), that is considered non-manifold, and will not work. You can force them together, but let’s leave that out for now.
As for boolean (in this case union, but same goes for difference, intersection and split), you need two (or more) volumes that actually overlap, eg. two spheres that partially occupy the same space. Objects in boolean operations don’t need to be closed, but the overlap needs to have a closed intersection; you can boolean union two spheres, but you can’t boolean a sphere and plane that doesn’t fully cut through the sphere.
MergeAllCoplanarFaces is for when you’ve joined or booleaned multiple objects where (at least part of) the result can be merged into a single, trimmed surface.
I think it might be a good idea for you to go through some of the beginner tutorials where a lot of the basic do’s and don’ts of NURBS modeling are covered. The “Level 1” and “Level 2” tutorials are a great place to start.
HTH, Jakob
*great explanation
and the text are ur edit or rhino indicate that ?*
That’s just me and the Dot command :grin:
-Jakob
