Surface from Oval Base and Variable Height Rail
Hello everyone,
I am working on a project in Grasshopper and I am struggling to create a clean surface for a complex oval shape.
The setup:
  • Base Shape: An oval constructed from two small radii at the ends, connected by a larger arc.
  • Longitudinal Profile: A long arc that defines the maximum height above the base plane.
  • Cross-Section: A small arc consisting of a specific radius that is mirrored.
My Goal: I want to generate a surface that precisely follows the outer oval footprint (base shape) while maintaining the height defined by the longitudinal arc. The cross-section (small arc) needs to be scaled at every position along the path so that the transitions remain clean and a correct, closed oval shape is created.
What would be the best approach to this setup?
I have attached a screenshot of my current canvas and the .gh file below.
Oval.gh (34.7 KB)
Thanks in advance for your help!
Use network Surface
Oval.gh (41.5 KB)
Thank you for the previous help! I am still struggling with a specific detail.
When using Network Surface, the resulting surface neglects the radius of the smaller arc. As seen in the attached image, there is a visible deviation between the surface and the input curve at its tightest point. I was hoping for the surface to follow this curve as strictly as it does the longer arc, but so far, even after experimenting with your file, I haven’t achieved a tight fit.
Is there a way to increase the influence of this specific curve within the network, to maintain that curvature of the small arc too?
Thanks in advance!
i did not see the smaller arc so i did not add it into network surface component. You saw the example of how i did it, just add this curve to network surface.
  • cutting the curves with planes =OK
    But last + first plane only have 1 intersection point. (so culled these two)
    The other 199 points can be used to create arcs (3pt)
    And just lofting them gives this result.
For you: Find a solution to get the first and last section closed.
Regards, Eef
OvalEW.gh (38.1 KB)
OK, let’s add the last parts too :wink:
OvalEW2.gh (41.6 KB)
