Surface from mesh
Hi, i know this is probably the long way round,
But i tried to convert this mesh into a surface by intersecting it with lots of lines,
And lofting the resultant lines of points.
It works, but the surface created is so complex and large, that i can’t work with it.
Is there anyway to simplify it or the process?
I eventually want to offset it horizontally to create a 3d printable solid.
Thanks
mesh2surface.gh (112.5 KB)
inner wall.stl (220.1 KB)
Pufferfish has a component called Mesh to Polysurface.
And Weaverbird has wbThicken, which you can use to give thickness to your mesh. Then bake it and export as .stl
