Surface from curve network help
I’m trying to make the top of my model surfaced but it is stopping at my second mid point that i made to make sure the top was flat and not bulged. Any help would be great
And then how might I go about surfacing the bottom half so that I can keep that nice curved grip at the bottom? fyi its a tv remote
pls post your file
TV Remote.3dm (435.7 KB)
there is a little overlapping piece of the curve which is most likely causing it. split or trim it then lock or hide it, see that it is not selected while doing the NetworkSrf later
also, join these curves into a singular curve each, in your model one of them was split into 2 curves not sure which at this point.
now you can select all curves with cmd a and use NetworkSrf, the curves will then have autosorted and it will work instantly,
though it is not a good quality outcome, you may have to introduce more section curves. or try a different approach.
Thank you very much! You are so helpful. The two curves in the middle seam to be joined to me. When i click on one of them the whole this is highlighted just like in your screen shot.
