Surface from a non-planar closed curve with guide curves inside
i have 6 curves that can make a closed curve (borders for surface) and 3 curves inside to guide the surface.
what is the best way to get a surface from this curves?
i also can redraw the curves if there is a method to get a similar surface but not with these curves.surface.3dm (283.4 KB)
Do you expect a single surface?
That will be hard if not impossible.
Hello - in plain Rhino, if you use the surrounding edges directly (for tangency) and the inner curves, there is a chance that Patchmight get you something. I’d use maybe 30 by 30 spans.
i was trying to make a single surface but that doesn’t really necessary. but even if i split it into pieces, the breaking lines between pieces should be as smooth as possible.
what is the best way to split it into pieces? or any other advice?
oh, i didn’t know i can use patch command with inner curves. it works. not exactly what i want now but i believe i will get it if i play some with curves.
Hello - the command works with History, so you can edit the input curves, in case that helps.
