I am trying to unroll the front surface of my model but there is no contour line to select. I see the contour line for the back surface, but not the front.
there should be a contour line just above my drawn in line in blue, but it isnt there
Hi Sarah -
Does running ShrinkTrimmedSrf
on the object make that isocurve appear?
If not, please post the 3dm file - it’s hard to debug from an image.
Thanks @wim . That did not work. I was able to get a new contour line on the back surface of the object, but not the front, which is the surface i need.
351432-0-B SR FACE 03.3dm (685.4 KB)
Hi Sarah -
There is no front surface on that object. Each hole has a cap in the front and when you shrink the surfaces, you will see that isocurves are drawn on each of those:
You’ve got some serious gaps between all those surfaces, though…
@wim hhmmm. i am importing this file from autocad. It is a 3d solid so there should be a surface and am not sure why there is a cap on the holes rather than a hole through a solid object
Sarah - can you post or send the original file?
