Surface expansion
happy day to all
how can i open the red surface as flat as the bottom surface
Since the following is straight, I can draw a rectangle without entering any commands and then wrap it with a curve command.(flow alang curve)
how do i turn on red surface variable
If I understand correctly you want a variable straight shape flow along curve right?
Then you can create variable shape with sweep2rail then use flow along curve.
