I want to create quad panels from this surface which is created in rhino. However, the surface topology is not smooth to create weaverbirds panels.
Anyone know how to edit the and make the proper panelling method?
I am currently working with surface which is used for quad paneling.
I’ve also had problems with divisions because of surface geometry.
What I’ve done to improve is:
- DupBorder of current surface
- Draw lines perpendicular lines connecting both vertical edges (these come from DupBorder)
- Use sweep2 to get clean surface. While doing it, adjust control points in settings panel to match a need for surface precision.
In my case it helped and made paneling way better than I got before.
I am not sure if this approach will solve your problem, but you definitely should give a try.
