Surface edge will be break small line
Hi
When
When I export step file, then import into bsuit cnc software. the edge of suface will be break into small lines.
Are there any command to control the number of line? or Rebuild
Attach file
Thank
Travis
Export surface.stp (134.0 KB)
Hi @travis.designer.vn
Try running MergeAllEdges on the surfaces and then exporting as STP. Does that come in any better?
Export surface_JN.stp (125.4 KB)
HTH, Jakob
Edit: There will of course always be edge breaks where the surface is split and at the tiny notches on the upper edge - if you want to avoid that, you have to build the entire surface as one and loose the notches.
Hi @Normand
Thank your advice. I’m try use Rebuild command.
Travis
