Surface.3dm (78.9 KB)
Hi Guys!
I need your help regarding on surface edges.
As you can see on the attached image on the surface on the left part, there was missing tangent node specifically on the fillet edge part.
Supposedly the edge tally would be 12 boundary edges like on the surface on the right part.
Is there a way I can convert/correct its boundary edges of the said surface? It seems -untrimborder command doesn’t work on this case.
Also attached original rhino file.
If anyone can off any help I’d really appreciate it.
Thanks
Russ
