Is this X,Y,Z or UV direction?
Please put it there, it’s unclear.
Thanks.
It is the parametric domain. A surface has two parameters, typically called u and v. These parameters both have a domain, and can vary between the domain’s lower and upper boundaries.
Thanks @menno,
Do you know a way to get the min/max x,y,z domain of a brepface?
Update:
I think I got it.
Something like this:
trimmed_surface = tmp_face.Trim(tmp_face.Domain(0),tmp_face.Domain(1))
Rhino.Geometry.Surface.GetBoundingBox(trimmed_surface,Rhino.Geometry.Plane.WorldXY)
Be careful, because a BRep face can be trimmed. I think it is better do something like
BrepFace bf;
using (var b = bf.ToBrep())
BoundingBox bb = b.GetBoundingBox(true);
Yep, I thought about that. I hope my solution is similar to converting to brep and getting the bounding box of that
Nope!
Why would:
BrepFace.Trim(BrepFace.Domain(0),BrepFace.Domain(1))
and
BrepFace.UnderlyingSurface()
give the same result?
Update:
HA:
BrepFace.ToBrep()
also gives the untrimmed surface
Update2:
BrepFace.Evaluate()
Also gives the untrimmed surface points.
BrepFace.ToNurbsSurface()… If I understood correctly.
Ah, nope, that wasn’t it - there was a trick though…
(this one always gets me)
This is it:
new_face=face.DuplicateFace(False)
Gets a new face that is “shrunk”
Try this on a trimmed surface:
import scriptcontext as sc
import Rhino
obj_id=rs.GetObject("Select surface",8)
brep=rs.coercebrep(obj_id)
new_face=brep.Faces[0].DuplicateFace(False)
bb=new_face.GetBoundingBox(True)
corners=bb.GetCorners()
rs.AddPoints(corners)
Nope, it’s still the untrimmed surface.
That’s the one, thanks a lot Mitch.
