Surface Domain at exact length?
newbie question here:
dividing surface by domain U and V parameter (between 0 to 1) gives a convenient way of dividing surface equally across a U or V surface direction.
but what if i need to divide the surface:
the first U curve is exactly 5 centimeter ofset from the first curve (Curve U parameter 0 plus 5cm distance)
The last U curve is exactly 5 centimeter ofset from the last curve (Curve U parameter 1 minus 5 cm distance)
using 1 simple component and simple 1 input slider [5 cm]
so far what i normally do is offset curve on surface, do it for both end curves. i think there should be more eellegant way of doing it by making use of this Parameterised surface.
(been thinking of measureing the length of curve in 1 end, (say 5,8 meters) divide it by 5 centimeter, then i got 0,00862xxx use it as input U parameter, but there should be way around this..
:slight_smile:
Not entirely true, or at least it depends on what you mean with “equally”.
Similarly to curves, also on surfaces parameter space is different from length space:
This ^ surface have uneven U control point distribution, so also a reparametrized 0.5,0.5 parameter will not fall in the “middle” in the length U space.
no, again, parameter space doesn’t correlate linearly with length space, only exception is when your nurbs object degree is 1 …
parameter space vs length space.gh (8.2 KB)
in this example, the outer border offset (white) is length-accurate, but then using one of its corner to evaluate isocurves on the same surface results in different shapes (blue).
It’s not simple to generalize what you need.
And this example is just 2D, on a 3D surface we could also discuss if to evaluate the 5cm offset in surface space or absolute distance (like cutting your surface with a pipe of radius 5cm) …
Can you describe further what is the context of your problem?
understood now. so my approach has been a little wrong. i guess offseting the surface inwards is the only way to go. thanks!
In the GH attached are two other possible solutions that might work for you. One uses Python.
SurfaceDomainAtLength.gh (51.5 KB)
