Surface division and offset
I am currently working on a project about shell structures. I created a surface and divided it into meshes. However, I want to divide the surface into equal-dimensional meshes. When I divide the U direction into 60, the dimensions between meshes have to be the same. According to my definition, the dimensions between meshes do not seem equal. How can I divide it into equal meshes? Furthermore, I want to offset the surface 10 cm above. When I offset it by 10 cm, it elevates from the ground as well. I want to keep the edge points at which I offset the surface on the ground or at the same height as my base surface. I have tried to explain what I want to do in the pictures. I need your bits of help. How can I solve these issues?
Thanks in advance,
surface division.gh (14.8 KB)
