Surface Different Result in Grasshopper not moving together
I have a Solid Difference geometry that I’m trying to orient to a curve, however, the resulting parts are orienting separately and I need them to preserve their initial arrangement. Does anyone know how I might do that?
I think the main issue results from this part, where the List Item carries more than one of the edges as the origin for the xy plane.
230801_Crown Model_EM.gh (32.6 KB)
main curves 2.3dm (70.2 KB)
I would opt for grouping all geometries to be oriented together, and then orient them in a single shot with an Origin Plane that is easy for you to identify
in alternative, if you want to keep things separate, you might want to use Transformation data from other successfull Orient operation done on Breps that are being oriented simultaneously (same transformation matrix)
Thank you!
