Surface Deformation
I am working on a definition that deforms the input surface and creates these three ‘bell-shapes’ based on the location of three attractor points, then it rotates the bell-shapes around their axis’s.
For some reason, I get three separate surfaces instead of one uniform surface with three bell-shapes.
I am also trying to create these ‘bumps’ at the bottom of the bell-shapes (similar to step 03 in the image below), which I am struggling to achieve.
Surface Deformation_WIP 1.gh (26.6 KB)
Much appreciate your help with this,
Thanks,
You didn’t internalise your base geometries…
Anyway, check if the attached definition is helpful or not for you…
SurfaceDeform_re.gh (17.4 KB)
Thank you,
