Why is this surface converted to a curve by the “Curve” component ? Because it is periodic ?
Feature or bug ?
Surface converted to curve.gh (14.4 KB)
Feature or bug ?
Did I manage to stump the whole community with that one ?
I guess because it can join all the naked edges in a single curve.
Well, OK, but it shits in the boots of my logic here.
I need to really sort curves.
If an automatic operation does not work for you, replace it. That’s not the designed way to extract the curves from a surface, it’s just a shortcut.
It’s the other way around : I don’t want to extract a curve from a surface, I want to filter actual curves.
I guess I’ll use Elefront’s “Filter by type” component :
@DavidRutten
In any case, there should be a clear description of the data conversions operated by the “container” components :
Ahh ya, GH1 does not have any type support, I also faced this problem sometime.
