I guess I have surface continuity problem with this simple ring. I checked continuity with EMap and Zebra. Can anyone say how can fix this problem?
bombato.3dm (2.2 MB)
Hi Eakan - I see some slight discontinuity here
To fix this:
ExtractSrf
the two surfaces. -
Hide
everything else DupBorder
UntrimBorder
MatchSrf
for Tangency, with Average set in the MatchSrf dialog. Looks like you need ‘Refine’ set as well. - Re-trim.
Show
the other parts,Join
Now… the above may have altered the shape enough that you may need to re-match some of the transition surfaces in order for it all to join up cleanly - normally you’d get that match across the larger surfaces set before creating the details.
Hi Pascal - After final Join I got some naked edges.
Have I use _JoinEdge (Join 2 naked edges) or MatchSrf?
I would also recommend rebuilding (simplifying) all your surfaces while you’re at it. It will help you achieve smoother surface matches.
Now, everything’s alright. Thanks Pascal.
