I have an issue with Rhino: I can’t seem to create a surface from two curves. As you can see in the picture, the number ‘0’ consist of two curves. I want to create a surface between these two curves. The surface must obviously follow the shape of the button.
The result should be so the numbers on the buttons have a solid color - not an outline.
See the attached
images
Thanks in advance!
-Kasper
