Suppress package manager dialog
During batch processing a lot of files I got this dialog popping up.
Is there any way to prevent these from showing?
Thanks
-Willem
Hi @Willem,
Can you provide me a simple way of reproducing?
Thanks,
– Dale
Hi Dale,
Reproduction can be done by importing this file with the script below
However I see that this popup is one time only.(making it a less severe issue for our use)
After a first run on a vanilla Rhino install with a click on ‘No’, a second run will not show the popup no more.
Thanks
-Willem
with_sections.3dm (23.1 KB)
file_path = r’C:\Users\Willem\Desktop\with_sections.3dm’
rs.Command(‘-Import “{}” Enter’.format(file_path))
Thanks @Willem - I’ve logged the issue.
– Dale
RH-89710 is fixed in Rhino 8 Service Release 25
