Supported objects by file format
Is there any compiled list of objects each file type support for export? to avoid empty files
Hello - not that I know of. Are you running into problems exporting?
no problems , only scripting result in empty files if choosen filetype does not support objects
I feel too lazy to start now to create a table of supported elements by file format
on the other hand : i wish to know if rhino schemes support load only selected plugins
run rhino as viewer does not need load any plugin except perhaps render and toolbars and is fast
some 3rd party plugin is taken too long to load
I cannot disable any plugin for an scheme without doing it for the others
Hi Javier -
No, that’s not possible.
Plug-ins are either loaded or unloaded for all schemes at the same time.
